Single Switch Module T1
With Neutral
Automate switch and socket and realize rich smart scenes
Single channel relay controller with flexible installation options and full support of smart home automation.
* This product needs to be paired with a Zigbee 3.0 hub device.
* This product can be placed into the cassette of the switch or socket, and only supports smart control of one switch button.
*Aqara hub (including G2H Camera Hub) is required for full functionality
Power Monitoring
Check power consumption reports and usage statistics to track the efficiency of your electrical appliances
Zigbee 3.0 Protocol
Enjoy the benefits of the fastest, most stable, and energy-efficient smart home technology
Compact Size
Fits almost any wall box and can be connected to your existing wall switch or outlet
2-way Switch Support
Can be connected to your existing 2-way switches and make them smart
Power Off Memory
You will be able to configure if you need the lights to turn on automatically after a power outage
Advanced protection
With overheat and overload protection, you can be sure your home is safe and secure
Timers and Remote Control
Schedule the usage of your electric appliances, check the status, and control them remotely
All-Round Compatibility
Supports most popular voice assistants and ecosystems
Automate your lights, ceiling fans, outlets, and more:
The Aqara Single Switch Module T1 will invisibly integrate into your existing wiring to make your home smart.
zigbee 3.0 Certifed Product
Enjoy the benefits of the fastest, most stable, and energy-efficient smart home technology.
For example, even if your internet connection or smart home hub goes down, your Zigbee 3.0 devices will keep communicating with each other.
Control Aqara Single Switch Module T1 using voice assistant
Control The Aqara Single Switch Module T1 using your favorite voice assistant and integrate it with other products supported by most popular ecosystems.
Aqara switch module T1 fits almost any wall box
Fits almost any wall box just behind your existing wall switch, and makes it smart.
High power limit* makes it a perfect solution to automate your wall outlet.
*Max 2200W of resistive load (With Neutral), to connect it to the wall outlet, With Neutral version is required
***The design of No Neutral and with Neutral versions may slightly vary
Connect Aqara sensors with The Aqara Single Switch Module T1 and forget about using your switches manually
Turn off the light if no motion is detected for 5 minutes
Hub
Single Switch
Single Switch
Motion Sensor
Motion Sensor
*Aqara Hub (including G2H Camera Hub) is required for this functionality
Turn on the lights when the door is opened
Hub
Single Switch
Single Switch
Door/Window Sensor
Configure automations based on the power consumption of your appliances
Turn off the lights when the TV turns on
Hub
Single Switch
Single Switch
Smart Bulb
How much power do your lights and other electrical appliances consume daily?
Monitor power consumption
The Aqara Single Switch Module T1 can monitor the power-consumption and generate a power curve diagram to make it easier for you to understand, which devices are most power-efficient and which are not.
