Wireless Mini Switch
Aqara Wireless Mini Switch
Easily control other smart home accessories with three actions.
One Button Control | 2 Years Battery Life
Designed to Fit Everywhere
No wiring required. The minimal design allows you to place it anywhere or attach it to a surface with a sticker.
Works with other HomeKit-enabled accessories in Apple Home app to make your life easier.
Works with Apple HomeKit
Aqara Home Automation
Along with other Aqara smart accessories, you can create various scenes. Single press to enable the alarm mode, double press to close the curtains and turn off the lights, and long press to turn off all appliances. Even if the Wi-Fi connection is unstable or disconnected, as long as the Hub is powered, automations associated with this product still work properly.
Smart Doorbell
Wireless Mini Switch can be used as a doorbell when combined with the Aqara Hub. You can also customize the ringtone through the Aqara App.
Emergency Button
The Wireless Mini Switch can also act as an emergency button at home. When pressed, Aqara Hub will send out a push notification and sound the alarm.
Advanced Technology
Aqara Wireless Mini Switch is a remote control switch with compact design and low energy consumption. Supports up to 50,000 presses*. Adopts V-0 grade flame-retardant PC panel that allows for high temperature resistance.
* Results may vary slightly under different circumstances.
