Water Leak Sensor
Aqara Water Leak Sensor
Detects flood and protects your property.
Triggers Aqara Hub Alarm and Push Notification | IP67 Dustproof and Waterproof Rating
IP67 Waterproof Rating
Aqara Water Leak Sensor meets IP67 dustproof and waterproof rating. It is guaranteed to work in humid and dusty environments.
Designed to Fit Everywhere
Aqara Water Leak Sensor can be placed anywhere according to your needs, guarding your home with its elegant design.
Restroom
Restroom
Basement
Basement
Kitchen
Kitchen
Balcony
Balcony
Works with other HomeKit-enabled accessories in Apple Home app to make your life easier.
Aqara Home Automation
Automatically Turns the Water Off
When Used with Solenoid Water Valve
Triggers Alarm When Flooding is Detected
When the water level reaches up to 0.5mm, the Water Leak Sensor will trigger the Hub to sound an alarm and send a notification to your phone.
leak detected
Leak Detected
app notification
App Notification
Sound Alarm
Advanced Technology
The outer shell is made out of anti-UV material and protects the sensor from discoloration.
The sensor is also energy efficient and one battery can last over 2 years under normal usage.
2 Years
2 Years
Replaceable
Water Leak Sensor Advanced Technology
