Aqara Vibration Sensor can be placed anywhere according to your needs, guarding your home.
													Aqara Vibration Sensor works with other HomeKit-enabled accessories in Home to make your life easier.
													When vibration, tilt or drop is detected, Aqara Vibration Sensor will trigger the Hub to sound an alarm and
send a notification to your phone.
You can customize different scenes with our suite of smart home products. Even if
the Wi-Fi connection is unstable or disconnected, as long as the Hub is powered, local automations associated with
this product still work properly.
													Aqara Vibration Sensor is embedded with a high precision acceleration sensor. The shell is made of
anti-UV material and the color will not fade allowing for long-term usage. It consumes low energy and
one button battery lasts about 2 years.
													Copyright © 2023 Lumi United Technology Co., Ltd. All Rights Reserved.
