Aqara Temperature and Humidity Sensor
Monitors temperature, humidity, and atmospheric pressure in real time.
No Wiring Required | Temperature and Humidity Reminder | 2 Years Battery Life
Data review.
The current data is displayed in the app. An alert notification will be sent to your phone when abnormal environment is detected.
Smart control in Apple Home app.
Works with other HomeKit-enabled accessories in Apple Home app to make your life easier.
Aqara home automation.
Along with other Aqara smart accessories, you can create various scenes. Even if the Wi-Fi connection is unstable or
disconnected, as long as the Hub is powered, automations associated with this product still work properly.
Automatically adjust indoor humidity with a humidifier.
* An Aqara Smart Plug is required.
Hub
Temperature and
Smart Plug
Automatically adjust indoor temperature and humidity to a comfort range.
* An Aqara Air Conditioning Controller is required and it is available in mainland China only.
Air Conditioning
Controller
Temperature and
Technologically advanced.
Aqara Temperature and Humidity Sensor adopts an industrial-grade sensor provided by the industry-renowned Sensirion
company which has the humidity detection accuracy of ±0.3℃ and temperature detection accuracy of ±3%.
The production process is strictly supervised to ensure high quality.
Model:
WSDCGQ11LM
Wireless Protocol:
Zigbee
Battery:
CR2032
Dimensions:
36 × 36 × 9 mm (1.42 × 1.42 × 0.35 in.)
Temperature Range and Precision:
-20° – +50 °C, ±0.3 °C
Humidity Range and Precision:
0 – 100% RH (no condensation), ±3%
Atmospheric Pressure Range and Precision:
30 kPa – 110 kPa, ±0.12 kPa
What's in the Box:
Temperature and Humidity Sensor x 1,  Sticker x 1, Quick Start Guide x 1
App:
Apple Home app (iOS 10.3 or later), Aqara Home app (Android 5.0 or later, iOS 10.3 or later)
