Overview
Specs
User Manual
Video
Where to Buy >
Model:
Single Rocker, WS-USC01
Double Rocker, WS-USC02
Input:
120 V AC 60 Hz
Product Colour:
White
Material:
PC
Dimensions:
120 x 74 x 36.5 mm (4.72 x 2.91 x 1.44 in)
Operating Temperature:
0℃~40℃ (32℉~104℉)
Wireless Protocol:
Zigbee 3.0
Operating Humidity:
0 – 95% RH, non-condensing
Maximum Load:
600 W/way(Incandescent), 200 W/way (CFL/LED), 1/4 HP Motor
Aqara smart light switch no neutral - light up your life as your wish
Aqara Smart Wall Switch
No Neutral
Light Up Your Life as You Wish
Remote Control | Set Timers | Voice Control | Automation
App remote control with our smart switch no neutral - turn lights off right away on your phone.
App Remote Control
Forgot to turn off the lights? No worries. Simply open Aqara Home or Apple Home app, check the status of your home lights, and turn them off right away on the app.
Set smart switch's timers in order to turn on/off automatically lights
Set Timers
Set timers for your lights and they will turn on automatically as you like.
Smart wall switch no neutral compatible with HomeKit Siri, Google Assistant and Amazon Alexa
Voice Control Your Lights
Ask your favorite voice assistant to control the lights in different rooms.
Smart lighting with our smart switch without neutral and door sensor
Light Up Your Home When You are Back
The lights will automatically turn on as soon as you arrive home to give you a warm welcome.
Smart lighting at night with our smart light switch and human motion sensor
Smart Night Lights, Special Care for You at Night
When you get up at night, the Smart Wall Switch will automatically turn on the light for you.
Remotely control lights with our smart switch and wireless switch without new wiring
Muti-way Control
Equipped with wireless switch, you can easily control the same lights from two or more locations without new wiring. Even if the network is disconnected, with Zigbee connection, your smart home devices will still function automatically.
Smart wall light switch adopts flame-retardant PC panel and withstands high temperature.
Multiple Safeguards, Safe and Reassuring
Adopts V-0 grade flame-retardant PC panel and withstands high temperature. Supports up to
100,000 times of physically on/off switching.
Aqara smart wall switch without neutral installation and setup
Aqara smart wall switch no neutral - light up your life as your wish US version smart swtich no neutral supporting remote control, set timers, voice control and automation. App remote control with our smart switch no neutral - turn lights off right away on your phone. Aqara smart wall switch us version controlled in the app. Set our smart switch's timers in order to turn on/off automatically lights Ask your favorite voice assistant to control the lights in different rooms rhrough our smart switch Smart wall switch no neutral compatible with HomeKit Siri, Google Assistant and Amazon Alexa Smart lighting with our smart switch without neutral and door sensor The lights will automatically turn on as soon as you arrive home to give you a warm welcome. Smart lighting at night with our smart light switch and human motion sensor When you get up at night, the Smart Wall Switch will automatically turn on the light. Remotely control lights with our smart switch and wireless switch without new wiring Remotely control lights with our smart switch and wireless switch without new wiring Smart wall light switch that adopts flame-retardant PC panel and withstands high temperature. Aqara smart switch no neutral hardware details and certifications Aqara smart wall switch without neutral installation Aqara smart wall switch no neutral setup Aqara smart wall switch without neutral specifications
