Smart Plug (US Version)
Aqara Smart Plug
Automate your ordinary appliances
Remote Control | Voice Control Enabled | Timer Mode Energy Monitoring | Overheat and Surge Protection
Aqara Smart Plug US
Aqara Smart Plug US
Remote Control Timer Switch for Appliances
With the Aqara Smart Plug, you can set schedules for your lights and appliances. Using the Apple Home or Aqara Home app,
you can control the lights and appliances anytime, anywhere.
Slide Large Heading
Slide Small Heading
Slide Large Heading
Slide Small Heading
Slide Large Heading
Slide Small Heading
Slide Large Heading
Slide Small Heading
Previous slide
Next slide
Turn on the coffee machine after waking up.
Turn off appliances remotely after leaving home.
Turn on the humidifier before arriving home.
Turn off the lights before going to sleep
Enjoy A Smart Home Even When The WiFi Is Disconnected
Through the Aqara Hub’s Zigbee connection, the Aqara Smart Plug can still be controlled with the Aqara Wireless Switch even when there is a weak WiFi signal.
Supports multiple voice assistants
Smart plug is compatible with Apple Homekit the Google Assistant, and Amazon Alexa. Highly compatible Smart Plug can connect with countless smart devices in the world to create your ideal smart home lifestyle.
supports multiple voice assistants
App Control
With the Aqara Home app (iOS or Android), you can control your home from almost anywhere at anytime.
App control
Voice Control
You can use Siri or Alexa to easily control the appliances connected to the Smart Plug.
Power Consumption Data
Aqara Smart Plug can record the power consumption of appliances on a daily/monthly basis, helping you monitor and save on your monthly energy bills.
* Aqara Smart Plug does not support appliances over 15A.
Overheat and Overload Protection
When the smart plug detects fluctuations, it automatically turns off the power to the appliances instantly.
Multiple Safeguards In Place to Ensure Your Safety
Utilizing V0 grade fame resistant material, the smart plug is safe and reliable.
It is also equipped with a protective shell to prevent electrocution.
The Aqara Smart Plug supports any appliances with a maximum power consumption of 1875W.
No installation required, 3 simple steps to use
Plug the device into the socket.
Plug the device into the socket. If the blue light blinks for a second, the device is properly powered. Short press once, if the red light blinks slowly, it indicates the device is working properly.
Follow the Aqara Smart Hub
Follow the Aqara Smart Hub quick start guide to add the Aqara Smart Hub to the app.
Open the Aqara App
Open the Aqara App and select “+” on the upper right corner of the main page. Select the “Smart Plug” follow the instructions on the screen .
