Overview
Specs
Faq
Model:
QBKG04LM
Operating humidity:
5%-95%RH (non-condensing)
Operating temperature:
-5℃~+60℃ (23℉~140℉)
Load range:
≤800W / circuit, 3W energy saving lamp / 5W LED lamp / 16W fluorescent lamp at minimum
Standard:
Q/QLML007-2016
Dimension:
86 * 86 * 15.12mm
Wireless Protocol:
Zigbee
Input voltage:
220V~, 50Hz for single live line
Wall Switch
Zigbee
Light your life as you wish.
※Aqara hub is required.
Aqara smart three-way switches vs. standard three-way switches
Aqara smart switch no neutral vs traditional wall switch
With three-way switches, you can control one lamp with two switches, e.g. Wall Switches at both top and bottom of stairs. Adding a 2nd wired switch requires pulling new wires which is labor intensive, time consuming, and intrusive.
Did your builder forget to install switches on both ends of a long hallway, or are there more convenient locations for your switches? With Aqara's Wall Switch, you can easily control the same lights from two or more locations without new wiring.
※ This function shall be matched with Wireless Mini Switch.
06:30
From beginning to end,
have a perfect day with Aqara
Set soothing light wake-up scenes to
tailor the system just the way you like.
07:00
Turn on light upon detecting people moving
Turn on the light wherever you go after you wake up.
sunlight in the morning, Aqara Wall Switch awakes and activates you to meet the new day.
※ This function works with the Aqara Motion Sensor
08:00
Turn off lights even when you are at work
Need to leave in a hurry?
Turn off all lights in your home via our smart phone app with a single click
19:30
Door opening triggers lamp to turn on
The light will automatically turn on to welcome you upon your arrival home,
detected by the door opening.
※This function works with the Aqara Door & Window Sensor.
22:30
Turn off lights with one touch
On a cold winter night, turn off all lights from your bedside switch
without traipsing around the homes
※It should work with Aqara Wireless Remote Switch to create this scenario.
Easily upgrading without replacing the original lamps.
Aqara Wall Switch can be easily and rapidly installed without changing the original lighting equipment and circuit.
commonly-used lamps can be flexibly controlled
only by replacing the traditional Wall Switch with an Aqara Wall Switch.
smart light switch no neutral replaces easily orginal lamps
Aqara Home Automation
aqara smart home ecosystem
High-quality Wall Switch
The Aqara Wall Switch, when matched with a Panasonic 16A Pickup Resistance Relay, can control lamps from 3W to 1500W.
Equipped with atemperature detection chip and 5A fuse, it can automatically shut off when detecting a load greater than 1500W
or the internal temperature exceeds 60 ℃. Supports up to 50,000 presses.
panel of Aqara smart switch without neutral
Aqara smart wall switch bracket
circuit board of Aqara smart wall light switch
Aqara Smart Home Wall Light Switch cassette
Quick connection  in 3 steps
smart wall switch setup step 1
smart wall switch setup step 2
smart wall switch setup step 3
Instructions for installation
Each rocker of the Wall Switch (Aqara Wireless Remote Switch Double Rocker) controls one lamp. The switch can be installed in the following steps:
1. Turn power off at the circuit breaker, remove switch cover plate, remove existing switch, replace with Aqara Wireless Remote Switch Double Rocker, connect live wire of wall junction box to Input Terminal L, then connect the lamp wire of wall junction box to L1 and L2 (Note: The lamps connected with L1 and L2 are controlled by the left button and right button respectively), and finally tighten the screw. See the drawing below for wiring:
smart switch without neutral wiring
2. Remove the switch panel with straight screwdriver.
smart switch without neutral installation 1
3. Secure the switch on the wall junction box with screw.
smart switch without neutral installation 2
4. Press down the switch panel.
smart switch without neutral installation 3
5. Turn on the main switch. You can confirm the Aqara Wall Switch is powered-on if the blue status indicator flashes once. Press the button, the switch is functional but not connected to a network when the red state indicator flashes slowly.
Download the client and install it according to the steps of “add device”.
Model:
QBKG04LM
Operating humidity:
-5℃~+60℃ (23℉~140℉)
Load range:
Standard:
Q/QLML007-2016
Dimension:
86 * 86 * 15.12mm
Wireless Protocol:
Zigbee
Input voltage:
