Aqara Hub
Smart Home Center | Security Voice Control Enabled | App Control
* Only supports 2.4 GHz Wi-Fi network.
aqara hub
Smart Home Center
Aqara Hub is a control center for an entire smart home. Connecting via Zigbee protocol, Aqara
accessories can still work smoothly even if your home network is unstable or disconnected.
* Up to 32 Aqara smart accessories can be connected to the Hub.
Works with Apple HomeKit
You can use Home app to control the Hub and its connected accessories. Aqara accessories can also work with other
HomeKit-enabled accessories to provide you a smarter home.
voice control
Voice Control
automation
Automation
Smart Home Center
Smart Home Center
Highly Secure
Highly Secure
* To control this HomeKit-enabled accessory, iOS 10.3 or later is recommended.
* Controlling this HomeKit-enabled accessory automatically and away from home requires an Apple TV with tvOS 10.2 or later or an iPad with iOS 10.3 or later or a Home Pod set up as a home hub.
Security
HomeKit technology provides advanced security with end-to-end encryption and authentication. Data related to your home is encrypted and stored in the keychain of your Apple device. It’s also encrypted in transit between your Apple device and the accessories you’re controlling in your home.
You can control Aqara accessories with Siri on your iPhone, iPad, Apple Watch or HomePod.
Just say “Siri, I’m home”, and the lights can automatically turn on for you.
voice control enabled mobile
Along with Other Aqara Smart Accessories to Create Various Scenes out of Your Unlimited Imagination
Lights are on when the room is occupied, lights are off while nobody is home.
When motion is detected in the evening, the Hub light automatically turns on.
hub icon
Hub
motion sensor
Motion Sensor
Smart doorbell, personalized ringtone.
With a press of the Wireless Mini Switch, the Hub plays your preferred ringtone.
hub icon
Hub
wireless mini switch icon
Security reminder, guarding your home.
With the Door and Window Sensor, you can turn on alarm mode when you leave the house or when you are asleep. If a door or window is opened, the Hub will sound an alarm and send a notification to your phone.
hub icon
Hub
door and window sensor
One button, all accessories under control.
With the Wireless Remote Switch, set your own night mode and turn off all the lights with a click of the button.
hub icon
Hub
Humidity and temperature adjustment, creating your comfort zone.
Link the Smart Plug with a humidifier to improve indoor humidity.
hub icon
Hub
smart plug
Smart Plug
Water leak alarm, protecting your property.
With the Water Leak Sensor, when a leak is detected, the Hub will sound an alarm and send a notification to your phone.
hub icon
Hub
Water Leak Sensor
Water Leak Sensor
Automation
hub icon
Hub
motion sensor
Motion Sensor
Lights are on when the room is occupied mobile
hub icon
Hub
Smart doorbell
hub icon
Hub
Security reminder
hub icon
Hub
One button
hub icon
Hub
smart plug
Smart Plug
hub icon
Hub
Water Leak Sensor
Water Leak Sensor
Water leak alarm
App Control
With the Aqara Home app (iOS or Android), you can control your home from almost anywhere at any time.
Advanced Technology
Aqara Hub adopts one body shell design and uses NXP i.MX6 CPU, 256M DRAM, 256M flash, and an
MFi chip. It has two high gain built-in antennas. By utilizing FR-4 PCB with a large area ventilated base,
the ventilation creates an airflow from front to back, increasing the heat dissipation and ensuring the
Hub’s reliability over time.
aqara hub advanced technology
No installation required, 3 simple steps to use
Connect the Hub to power supply.
Open the Aqara Home app
Open the Aqara Home app, press “+” in the upper right corner to add the Hub.
After the Hub is successfully added, add remaining Aqara accessories as needed.
Aqara Hub has received the following certifications
certifications
certifications
certifications
