Single channel relay controller with flexible installation options and full support of smart home automation.
* This product needs to be paired with a Zigbee 3.0 hub device.
* This product can be placed into the cassette of the switch or socket, and only supports smart control of one switch button.
*Aqara hub (including G2H Camera Hub) is required for full functionality
Even if your wall box doesn't have a neutral wire, the Aqara Single Switch Module T1 can be installed and used
Enjoy the benefits of the fastest, most stable, and energy-efficient smart home technology
Fits almost any wall box and can be connected to your existing wall switch or outlet
Can be connected to your existing 2-way switches and make them smart
You will be able to configure if you need the lights to turn on automatically after a power outage
With overheat protection, you can be sure your home is safe and secure
Schedule the usage of your electric appliances, check the status, and control them remotely
Supports most popular voice assistants and ecosystems
For example, even if your internet connection or smart home hub goes down, your Zigbee 3.0 devices will keep communicating with each other.
Control The Aqara Single Switch Module T1 using your favorite voice assistant and integrate it with other products supported by most popular ecosystems.
High power limit* makes it a perfect solution to automate your wall outlet. *Max 2200W of resistive load (With Neutral), to connect it to the wall outlet, With Neutral version is required
*Aqara Hub (including G2H Camera Hub) is required for this functionality
*By signing up, you agree to receive marketing emails from Aqara. You can unsubscribe anytime.
Copyright © 2026 Lumi United Technology Co., Ltd. All Rights Reserved.
