Aqara Motion Sensor
170⁰ degree motion detection
Peel & Stick | Remote Notification
Automatically Turns Lights on or off l 2 Years Battery Life
Aqara Motion Sensor
Place It Wherever You Want
No tools required for installation. With a sensor stand and sticker, you can set the motion sensor wherever you want. The stand can make a 360 rotation and you can easily adjust the detection angle.
Place
Place
Attach
Attach
Invert
Invert
Works with other HomeKit-enabled accessories in Apple Home app to make your life easier.
Works with Apple HomeKit
A Complete Smart Home Solution
We offer a comprehensive suite of smart home products that allow you to create endless combinations of use cases and customized scenes.
Through the Aqara Hub’s Zigbee connection, Aqara devices can still operate locally even when there is a weak WiFi signal.
Aqara Home Automation
Security Notification
With the Motion Sensor, you can turn on alarm mode when you leave the house. If motion is detected, the Hub will sound an alarm and send a notification to your phone.
hub icon
Hub
motion sensor
Motion Sensor
Smart Night Light
When motion is detected in the evening, the Hub light automatically turns on.
hub icon
Hub
motion sensor
Motion Sensor
Smart Night Light
hub icon
Hub
motion sensor
Motion Sensor
Smart Night Light
Security reminder, guarding your home
hub icon
Hub
motion sensor
Motion Sensor
security notification
Advanced Technology
A Japanese infrared sensor is used to detect human motion through the moving heat source and the US Polyolefin Fresnel lens is used for high precision detection. The shell is made of anti-UV material and the colour will not fade allowing for long-term usage. The high quality flame-retardant material is used to improve safety.
