Cube T1 Pro
Aqara logo
Cube T1 Pro
'Turn' to have more fun in smart controlling.
all round compatibility
Support Popular Ecosystems
Thanks to the new Scene Mode, the Cube T1 Pro now can be used as a HomeKit controller. Moreover, it also supports Alexa, IFTTT and other ecosystems*.
Side & Action Control for Scene Mode
With dice-like indicators, you are able to use 6 sides to control different scenes or devices. Rotating, shaking, holding or triggering after one-minute inactivity will create more possibilities.
Action Mode from the Classic Cube
Alternatively, you can switch the T1 Pro to the Action Mode. Push, shake, rotate, tap twice, flip 180°, flip 90° and trigger after one-minute to enjoy more fun while retaining other benefits.
Future-Proofing via OTA*
The Cube now supports OTA updates, which means that new features and fixes can be added after the release of the product.
Battery Life
Up to 2-Year Battery Life
The ultra-low energy consumption will make it more environmentally friendly and let you forget about charging the batteries for years.
Rotate to Control
You can adjust the brightness or the temperature of other Aqara lights** or curtain opening percentage by rotating the cube: everything is configurable in the Aqara Home app.
* An Aqara Zigbee 3.0 hub is required.
** Compatible Aqara lights are required.
Support HomeKit and Alexa! Wider Compatibility Makes Infinite Possibilities
We've made the T1 Pro much more versatile: now it supports HomeKit, Alexa, IFTTT and more*
aqara home
Aqara Home
home
Home
alexa
IFTTT
IFTTT
Now, you can use each of its six sides to control third-party devices, for example, flip it to side 5 to trigger an Alexa routine that controls the lights, and flip it to the side 2 to turn on HomeKit-compatible thermostat.
speaker
Ecosystem support now lets the Cube T1 Pro control practically any compatible third-party device:
Lights
Lights
Locks
Locks
Outlets
Outlets
Thermostats
Thermostats
Fans
Fans
Air Conditioners
Air
Conditioners
Cameras
Cameras
Security
Security
* Matter support may be unavailable by the time of the launch, and will be rolled out as an OTA update of a compatible Aqara Zigbee 3.0 hub
** In HomeKit, the T1 Pro can be configured as a wireless switch with 6 “buttons” (each button represents one of 6 sides of the cube)
*** In Alexa, the T1 Pro is exposed as 6 “motion sensors”. Flipping the Cube to each of its sides triggers one of 6 “sensors”.
Find More Joy in Scene Switching
Rolling the dice! No need to memorize all the actions, now we have clear dice-like indicators for each side and you are able to use each of them to control different scenes or devices. Apart from that, actions like rotating, shaking or holding for different sides create more possibilities.
Good Morning Scene
Face 1 up to disable the alert mode, open the curtains and turn on the coffee maker.
good morning scene
Romantic Scene
Face 3 up to turn the LED strip into Custom colors.
romantic scene
Cleaning Scene
Face 5 up to start the robot vacuum cleaning.
cleaning scene
Good Evening Scene
Shake to turn off all the light, turn on the heater and night light.
good evening scene
Switch to Action Mode for Effortless Magic Control
Alternatively, if you just want to make it simple and playful, you are able to switch to the classic Action Mode*.
Play around with your family!
*Action Mode is only available in Aqara Home and cannot be used with Scene Mode simultaneously
turn off the lights in bedroom
push to turn off the lights
rotate to dim the lights in living-room
rotate to dim the lights text
tap twice to open or close the curtain room
tap twice to open or close text
flip 180 degress to arm aqara alert
flip 180 degree to alert aqara home system text
Moreover, shaking, flipping and triggering after one-minute inactivity make up to 7 actions alternative for your creativity in smart controlling.
* Action Mode and Scene Mode can not be used simultaneously
Compact and premium design, with built-in high-accuracy and low-consumption sensor
Perfect couple! Use Cube T1 Pro to control the Camera Hub G3
Cube T1 pro + Camera Hub G3
IF Cube is flipped to the side,  THEN Switch G3 to Gesture Recognition mode.
IF the Cube is flipped to the side 3,  THEN turn the G3 to the entrance door.
IF the Cube is flipped to the side 5,  THEN turn on the G3’s Privacy Protection mode.
Thanks to G3’s built-in Zigbee gateway function, no additional hub is needed.
Use one action or rotate to fully control your Curtain
Cube T1 pro + Hub +curtain driver
You can adjust the opening percentage of curtain or roller shade by rotating the cube, or using one action: shake the Cube once to open the curtain, shake it once again to stop the curtain at a desired position, and shake it once more if you want to close them: no need to use three different actions!
Moreover, compared to the old Cube, now it supports rotating with different faces up, which makes 5 more groups of devices controllable by that action!
