Radiator Thermostat E1
Aqara logo
A smarter, more comfortable and energy-saving heating control experience for your home.
connectivity icon
Zigbee 3.0 Protocol and Matter Support*
Enjoy the benefits of the fastest, most stable, and energy-efficient Zigbee 3.0 technology and be sure about the future with Matter support.
Colorful Backlit Display
The Thermostat has a colorful backlit display, for increased viewing angle, extra high contrast as well as crisp and colorful icons.
Geofencing and Multi Home Support
The geofencing technology will start the heating before arriving home. Even if you have more than one home, you will be able to set up independent automations.
Configurable Smart Schedules
The schedules can be set for the desired periods of time, such as different temperature settings for day and night, and the transition between them will be smooth and fast.
External Temperature Readings**
The Thermostat can receive the temperature readings directly from the connected Aqara Temperature and Humidity Sensor from another corner of the room, even in HomeKit!
Device Grouping Support
In the case of having multiple radiators in one room, all of them will be synchronized in the most efficient way based on the actual temperature of the room.
10 Year Battery Life
1-Year Battery Life***
No need to change the batteries after a few weeks of usage: thanks to the Zigbee 3.0 protocol and energy-efficient hardware, the Aqara Radiator Thermostat's battery can last up to one year.
Easy Installation and Wide Compatibility
The Thermostat includes adapters that make it compatible with the majority of radiator valves. It only takes a few minutes for installation and does not require additional tools.
* Matter support may be unavailable by the time of the launch, and will be rolled out as an OTA update of a compatible Aqara Zigbee 3.0 hub
** Aqara Temperature and Humidity Sensor, TVOC Air Quality Monitor are required
*** Battery life may vary depending on the usage
**** An Aqara Zigbee 3.0 hub is required
Wide Compatibility
Compatible with the most popular ecosystems and can be controlled by voice. Apple HomeKit, Alexa, Google, IFTTT, and Alice are supported. Matter support will be available via OTA update of supported Aqara Hubs after the official release of Matter specifications.
aqara home
Aqara Home
home
Home
alexa
IFTTT
IFTTT
alice
Alice
speaker
Configurable Control Methods and Sensor Linkage on Demand
Smart regulation
The Thermostat can receive temperature readings from the connected Aqara Temperature and Humidity Sensor or TVOC Air Quality Monitor*, which will make the control of temperature more accurate for the whole room, not just around the radiator. It also works in HomeKit!
Aqara Home
Aqara Home
Apple Home
Configurable schedules
The Thermostat can be controlled remotely. Moreover, you can also set schedules for the desired periods of time, such as different temperature settings for day and night. The transition between them will be smooth.
Geofencing support
Geofencing support
No more entering a cold home. By setting the geofencing, the Thermostat will start heating before you arrive. Even if you have more than one home, you will be able to set up the independent automations for each of them.
* An extra Aqara Temperature and Humidity Sensor or TVOC Air Quality Monitor is required
Save Energy With No Compromise of Comfort
Device grouping support
Advanced Door and Window Opening Detection
The Thermostat E1 supports automatic door and window opening detection, that will turn off the heating to save energy in case of such events*. Also, compared to the competition, it can be linked to the Aqara Door and Window Sensor to increase the detection accuracy.
* The option can be disabled in settings.
Freezing Protection
By setting a low temperature protection such as 5°C, the Thermostat is able to guard the pipes from freezing and exploding even when you are away from home.
Easy to Use, and Designed to Fit Everyone's Home
Radiator Thermostat E1 Easy self installation
Easy self-installation
The Thermostat includes adapters that make it compatible with the majority of radiator valves. No additional tools required. Just follow the manual or the installation video, you will finish it in a few minutes.
Radiator Thermostat E1 Easy Colorful Backlit Display
Colorful backlit display
Compared to similar products, the Aqara Radiator Thermostat's LCD screen has backlight of its premium display, so you can easily know the status and specific temperature.
Radiator Thermostat E1 1-year battery life
1-Year battery life*
No need to change the batteries after a few weeks of usage: thanks to the Zigbee 3.0 protocol and energy-efficient hardware, the Aqara Radiator Thermostat's battery can last for one year.
*No need to change the batteries after a few weeks of usage: thanks to the Zigbee 3.0 protocol and energy-efficient hardware, the Aqara Radiator Thermostat’s battery can last for one year.
Adjust the temperature based on each person's preference
Thanks to Camera Hub G3’s local face recognition, the room temperature may be adjusted automatically based on each person’s preferences.
IF G3 recognizes a particular person’s face
THEN his/her room may start heating while other rooms won’t OR the Radiator Thermostat will increase or decrease the room’s temperature according to the pre-set preference
Radiator Thermostat E1 + Camera Hub G3
Aqara Home Geofencing and Weather automations will start heating before you arrive home
IF approaching home is detected or the outside temperature dropping sharply.
THEN the Radiator Thermostats will start heating
As a result, you will enter a cozy, warm home, with no energy being wasted.
Check whether your valves are compatible here.
The E1 supports most popular radiator valve standards thanks to the following adapters included into the package: standard screw of M30*1.5mm as well as Danfoss RA, RAV, RAVL valves are supported.
M30*1.5mm
M30*1.5mm
RA
RA
RAV
RAV
RAVL
While it is only compatible with thermostatic valves, others such as manual, return temperature limiter (RTL) and monotube radiator systems are not supported. However, in the majority of cases, it is relatively easy to convert the existing radiator valve to a supporting one using an aftermarket adapter. Please consult professional installers or official Aqara distributors for more details.
Thermostatic Valves
Thermostatic valves
