Customize the perfect ambience for every room, from a dim bedroom to a bright kitchen. Seven preset modes for your daily life and you can also customize your preferred scene.
Aqara LED Light Bulb color temperature: 2700K-6500K
You can control lights via the app when you are away from home. No need to worry about forgetting to turn off lights. Turn on the ambient light when you are heading back home. Simply tap your phone to turn off all lights at night and enjoy your sound sleep.
Ask your favorite voice assistant to turn on/off, adjust brightness and color temperature for you.
* Aqara Hub is required and sold seperately.
When you open the door in the evening, Door and Window Sensor will be linked to control the Aqara LED bulbs. No matter how late you get home, the light automatically turns on.
It turns on the light when you are here. It turns off the light when you walk away.
For example, you can rotate the Cube Controller to adjust brightness, push it to change the color temperature, shake it to turn on or off the light.
Set different light schedules to make your life more comfortable.
( Brightness 5%, color temperature 6500k)
( Brightness 50%, color temperature 4000k)
( Brightness 100%, color temperature 4000k)
( Brightness 75%, color temperature 2700k)
When your home network is unstable or disconnected, as long as the Hub is powered, automations associated with the Aqara LED Light Bulb still work properly.
Copyright © 2023 Lumi United Technology Co., Ltd. All Rights Reserved.
