Aqara Smart Plug
Make ordinary appliances smart.
Remote Control | Timer Control | Voice Control
Energy Report | Overheat and Overload Protection
Remote control timer switch for appliances.
With the Aqara Smart Plug, you can set schedules for your lights and appliances. Using the Apple Home or Aqara Home app,
you can control the lights and appliances anytime, anywhere.
Turn on the coffee
machine after waking up.
Turn off appliances remotely
after leaving home.
Turn on the humidifier
before arriving home.
Turn off the lights
before going to sleep.
Smart home even if the
Internet is disconnected.
When your home network is unstable or disconnected, as long
as the Hub is powered, automations associated with the Smart
Plug still work properly.
Voice control.
You can use Siri or Alexa to easily control the appliances connected to the Smart Plug.
Energy report, using appliances smartly.
Aqara Smart Plug can monitor the power consumption of appliances, recording the usage on a daily/monthly basis,
and helping you use appliances and savings smartly.
* Aqara Smart Plug does not support appliances over 15A.
Overheat and overload protection.
When the smart plug detects fluctuations, it automatically
turns off the power to the appliances instantly.
Multiple safeguards, safe and reassuring.
Utilizing V0 grade flame resistant material, it's safe and reliable. The plug is equipped with a
protective cover to prevent accidental electrocutions. It supports any appliance with a max
power consumption of 1875W.
3 Simple Steps to Use.
Plug the device into the socket. If the blue light
blinks for a second, the device is properly powered.
Short press once, if the red light blinks slowly, it
indicates the device is working properly.
Follow the Hub quick start guide
to add the Hub to the app.
Open the app and select the “+” in the upper
right corner of the main page. Enter the add
accessory page and select the Smart Plug
then follow the instructions on screen.
*If the connection fails, move the smart plug closer to the Hub and try again.
Model:
ZNCZ12LM
Color:
White + Gray
Main Material:
PC
Weight:
88g
Dimensions:
67 × 47 × 35 mm
(2.64 × 1.85 × 1.38 in.)
Wireless Protocol:
Zigbee
Electrical Rating:
1875 W, 15 A,
100 – 125 V AC, 60 Hz
Operating Humidity:
0 – 95% RH,
no condensation
Operating Temperature:
-10° – +40° C
What's in the Box:
Smart Plug,
Quick Start Guide
App Support:
Apple Home app (iOS 10.3 or later),
Aqara Home app (Android 5.0 or later, iOS 10.3 or later)
