※Mi/Aqara hub is required.
Aqara smart three-way switches vs. standard three-way switches
With three-way switches, you can control one lamp with two switches, e.g. Wall Switches at both top top and bottom of stairs. Adding a 2nd wired switch requires pulling new wires which is labor intensive, time consuming, and intrusive.
Did your builder forget to install switches on both ends of a long hallway, or are there more convenient locations for your switches? With Aqara's Wall Switch, you can easily control the same lights from two or more locations without new wiring.
※ This function shall be matched with Wireless Switch Mini.
06:30
From beginning to end,
have a perfect day with Aqara
Set soothing light wake-up scenes to
tailor the system just the way you like.
07:00
Turn on light upon detecting people moving
Turn on the light wherever you go after you wake up.
sunlight in the morning, Aqara Wall Switch awakes and activates you to meet the new day.
※ This function works with the Mi Motion Sensor
08:00
Turn off lights even when you are at work
Need to leave in a hurry?
Turn off all lights in your home via our smart phone app with a single click
19:30
Door opening triggers lamp to turn on
The light will automatically turn on to welcome you upon your arrival home,
detected by the door opening.
※This function works with the Mi Door & Window Sensor.
22:30
Turn off lights with one touch
On a cold winter night, turn off all lights from your bedside switch
without traipsing around the homes
※It should work with Aqara Wireless switch to create this scenario.
Easily upgrading without replacing the original lamps.
Aqara Wall Switch can be easily and rapidly installed without changing the original lighting equipment and circuit.
commonly-used lamps can be flexibly controlled
only by replacing the traditional Wall Switch with an Aqara Wall Switch.
Match Aqara Wall Switch with Mi sensors  to achieve various functions
You can match Aqara's Wall Switch with other Mi Sensors to achieve various functions.
More ZigBee devices connected to the system means a better user experience.
High-quality Wall Switch
The Aqara Wall Switch, when matched with a Panasonic 16A Pickup Resistance Relay, can control lamps from 3W to 1500W.
Equipped with atemperature detection chip and 5A fuse, it can automatically shutoff when detecting a load greater than 1500W
or the internal temperature exceeds 60 ℃. The panel can be switched up to 50,000 times.
Quick connection  in 3 steps
Instructions for installation
Each rocker of the Wall Switch (Aqara Double Rocker Switch) controls one lamp. The switch can be installed in the following steps:
1. Turn power off at the circuit breaker, remove switch cover plate, remove existing switch, replace with Aqara Double Rocker Switch, connect live wire of wall junction box to Input Terminal L, then connect the lamp wire of wall junction box to L1 and L2 (Note: The lamps connected with L1 and L2 are controlled by the left button and right button respectively), and finally tighten the screw. See the drawing below for wiring:
2. Remove the switch panel with straight screwdriver.
3. Secure the switch on the wall junction box with screw.
4. Press down the switch panel.
5. Turn on the main switch. You can confirm the Aqara Wall Switch is powered-on if the blue status indicator flashes once. Press the button, the switch is functional but not connected to a network when the red state indicator flashes slowly.
Download the client and install it according to the steps of “add device”.
  Parameters
Name:Aqara Wall Switch
Model:QBKG04LM
Operating humidity:5%-95%RH (non-condensing)
Operating temperature:-5℃-+60℃
Load range:≤800W / circuit, 3W energy saving lamp / 5W LED lamp / 16W fluorescent lamp at minimum
Standard:Q/QLML007-2016
Dimension:86*86*15.12mm
Wireless type:ZigBee
Input voltage:220V~, 50Hz for single live line
