Check Compatibility
Step 1 Take a look at your system
Aqara Thermostat Hub W200 isn’t compatible with your system if your thermostat is labeled 110V or 120V.
Step 2 Enter the wires
Select all the connectors on your thermostat base that attach to wires leading behind the wall.
Rh
R
Rc
AUX or E
V+Vg
C
G or G1
G2 and G3
ABCD
W2
W3
W or W1
HUM
PEK
Y2
Y3
Y or Y1
X
DHUM
B
O/B or OB
W2/AUX
Other
Don’t see what you’re looking for?
Show more connectors
Great news, Thermostat Hub W200 is compatible with your system!
Great news, Thermostat Hub W200 is compatible with your system! Since you don’t have a C-Wire, you’ll need the Aqara C-Wire Adapter (sold separately) for reliable power supply.
Based on your wiring selection, the Thermostat Hub W200 may not be compatible with your system. You can visit our specific guide or contact our support team for further confirmation.
