What is Dual Protocol (Thread/Zigbee Support)?
The device features dual protocol support: in Thread mode, no hub is required to connect to third-party Matter ecosystems*, while Zigbee mode** allows for exclusive Aqara functionalities. It also supports backward compatibility with the classic Aqara Zigbee hubs without compromising Matter support. You can switch between desired protocols based on preference.
* To use the device with a particular Matter ecosystem, a Thread-enabled Matter Controller of this ecosystem is required.
** Aqara Zigbee hub required
Device Adding
Using Thread
Thread = a network protocol that Matter can run on (native).
If a device speaks Thread, and Matter is turned on, it can talk directly to a Matter Controller (Apple HomePod, Aqara Hub M3, etc.) without translation.
Thread-Enabled Matter Controller
Requires
HomePod
Echo Show
M3
Matter Ecosystems of Choice
Using Zigbee
Zigbee = an relatively older network protocol (like Thread, but not natively supported by Matter).
Aqara Zigbee Hub (Matter Bridge)
Requires
M100
M3
Aqara Home
Requires
Same Aqara Zigbee Hub (Matter Bridge)
Matter Ecosystems of Choice (optional)
OR
Features
Matter Standard Features
and
Exclusive Features of Aqara Home
Thread/Zigbee Pros
Choose Thread if
you want direct Matter integration, future-proofing, and cross-brand compatibility.
No hub, no hassle
Connect directly to Apple Home, Google Home, Alexa, or SmartThings without needing an Aqara hub in the middle.
Future-ready
Thread is the backbone of Matter, which means you’re set up for the next wave of smart home adoption.
Rejoining reliability
With Thread, devices can automatically rejoin another hub if one goes offline, ensuring your smart home keeps running smoothly-something Zigbee simply can’t do.
Stronger Mesh
Seamlessly join the same Matter-over-Thread ecosystem alongside other brands, strengthening your mesh network and making your setup more reliable.
Local binding
End devices (endpoints) in a Matter installation communicate directly with each other.
Choose Zigbee if
you want full Aqara functionality, extended life for battery devices, and backward compatibility with your existing Aqara setup.
Unlock Aqara’s full potential
Get access to advanced features like complex automations,device groups, and smart behaviors that Matter alone can’t deliver.
Backwards-friendly
Works seamlessly with your existing Aqara Zigbee hubs and keeps older devices in play.
Proven stability
Zigbee is a mature, rock-solid protocol that powers Aqara’s large device portfolio with reliability you can count on.
Easier commissioning
The hub automatically discovers any nearby Zigbee sub-device in pairing mode. No QR codes, no scanning.
One app, one ecosystem
Perfect if you’re already invested in Aqara and want to expand building on the current setup.
Thread/Zigbee Feature Comparison
Aqara Home via Zigbee
Aqara Home via Thread
Conntact Sensors
Temperature Sensing
Wireless Switch (single press)
Power-Off Memory
Static Effects
Adjustment
On/Off Transition Setting
Brightness Control
Humidity Sensing
Power Monitoring
Smart Calibration
Color Temperature
Custom Press Mode
Custom Calibration
Calibration Reminder
Freeze Protection
MARS Tech
Decoupled Switch Mode
Route Recalibration
Dimming Curve
Relay Lock
Indicator Light Setting
* Regardless of device type or SKU, all features are listed for informational purposes only.
How to Switch Protocol
Network Reset *
Long press for 5 seconds
OR
Factory Reset*
Press consecutively 10 times
* This is a representative example of a product reset. Rest methods will differ depending on the model.
Select Device Protocol
The device supports multiple communication protocols. Please select the appropriate connection method based on your home gateway and usage requirements.
Thread protocol
Can connect to third-party Matter ecosystem platforms, suitable for multi-brand device interconnection. Requires an Thread Border Router.
Zigbee protocol
Supports more Aqara exclusive functions, with more stable and faster local linkage. Requires an Aqara Zigbee hub.
Thread/Zigbee Device List
2 Buttons, 1 Channel
2 Buttons, 2 Channels
4 Buttons, 3 Channels
GU10, RGB CCT / GU10, CCT
E27, RGB CCT / E27, ССТ
E26, RGB CCT / E26, ССТ
4 Buttons, 2 Channel
FAQ Tabs
FAQs about Matter
1. How to Switch from Thread to Zigbee Protocol?
1) Install the Aqara Home app, and enable Wi-Fi and Bluetooth.
2) Reset the device to factory settings (press any button 10 times continuously) to enter network setup (first-time device adding will automatically enter networking), which shows slow-blinking indicator.
3) In the Aqara Home app, tap Add Accessory, scan the Matter code on the button, select Zigbee under Switch Protocol page. Proceed following the app’s instruction.
2. How to Switch from Zigbee to Thread Protocol?
1) Install the Aqara Home app and enable Wi-Fi and Bluetooth.
2) Restore the device to factory settings (press any button 10 times consecutively), then enter network configuration mode.
3) In the Aqara Home app, tap “Add Accessory,” bring your phone close to the device, and the device will appear in the top left of the app. Tap the icon, select Thread on the “Switch Protocol” page, and follow the app instructions to complete setup.
3. What is the default protocol of this product?
The default protocol is Thread. Note: Factory reset will not change the current protocol until you switch to your desired one.
4. How to Identify the Current Communication Protocol?
1) After restoring factory settings, check the LED indicator light to identify current protocol during device adding: Green/Blue blinking: Thread protocol Yellow/Purple blinking: Zigbee protocol Red: Adding Timeout *The blinking color may vary depending on the model and region. Please refer to the device’s FAQ for accurate details.
2) In the Aqara Home app, go to device’s setting page, tap “…” on the top right, tap “Communication Protocol”.
5. Why can't the Matter over Thread device connect to the Aqara Hub (that is Thread-Enabled Matter Controller) ?
1) Make sure the Aqara Home app and the Aqara hub are updated to the latest firmware version.
2) Check if your phone and the Aqara hub are on the same local network.
3) Ensure that the Aqara hub is set as the primary Matter Controller: Go to the hub’s device page > Tap the “…” on the top right corner > “Matter Controller” > “Select Matter Controller”.
4) Try restarting the hub: Go to the hub’s device page > Tap the “…” on the top right corner > “Restart the Device”.
5) If it still doesn’t work, try creating a new Thread network: Go to the hub’s device page > Tap the “…” on the top right corner > “Network Information” > “Thread Network Management” > Switch or Create a new Thread network.
