One of the most compelling features offered by modern smart homes is the ability to controlliand operate your home appliances and devices with smart home assistants like Alexa.
With the Alexa smart home hub, every device you connect to the hub can be managed from your smartphone, tablet or via voice. All you need to do is download the Alexa app on your iOS or Android device to gain this functionality.
Many smart home devices are compatible with Alexa. One type of device you can control with Alexa is a smart lock, which makes it possible to lock or unlock your doors without a key.
Depending on the exact lock you obtain, you’re able to open these doors with your voice or code. Everyone in your family can have a different code that they input when they wish to enter your home.
If you’re looking for the best smart locks compatible with Alexa on the market, check out the options you can choose from in this article.
Table of Contents
Why Would You Need Your Smart Lock To Work With Alexa?
Along with the fact that a smart lock makes your home safer and more secure, pairing your smart lock with Alexa allows you to control the locking functionality with voice commands. You won’t need to manually input a code or use a key to unlock your door. Here’s how you can set up a simple yet powerful DIY home security system.
The Best Alexa-compatible Smart Locks
There are many Alexa-compatible smart locks available to you, which include everything from the Smart Lock U100 to the Smart Lock N100 Zigbee.
Aqara Smart Door Locks
Aqara offers a range of door locks that you can use to safeguard your home or keep your office secure. All Aqara smart locks are compatible with Alexa, Amazon’s virtual assistant technology.
Regardless of the model you choose, you’ll benefit from keyless entry, more convenience, ample versatility, and remote access.
Aqara locks are equipped with many useful features that extend from tamper alerts and multiple user access to activity logs and voice control. The seamless integration into smart home hubs ensures that your smart lock is easily controllable even when you’re on the move.
Aqara Smart Lock U100
The Aqara Smart Lock U100 provides you with a stylish and highly secure lock that has many of the same features that come with the more advanced smart lock models. You’ll benefit from a built-in fingerprint reader that’s able to store up to 50 distinct fingerprints.
The matte keypad gives you the ability to set one-time, periodic, or permanent passwords. In the event of an emergency, this smart lock also comes with a USB-C charging port as well as a mechanical key that accommodates manual entry. With the inclusion of Alexa functionality, you can also open the lock with your voice.
Aqara Smart Door Lock D100 Zigbee
The Aqara Smart Door Lock D100 Zigbee is a feature-rich smart lock that’s designed to be fully automatic. There are nine separate unlock methods available to you, which include everything from Alexa and NFC card to Aqara Home and your fingerprint.
These locks are outfitted with dual speakers that allow you to easily hear the sound that occurs whenever someone enters your home or inputs an incorrect password. If you activate the Child Safety Mode, any younger children you have will be unable to accidentally open the door by pressing the unlock button. The lock supports many different types of doors and can be paired with doors that have thicknesses between 40-120 mm.
Aqara Smart Door Lock A100 Zigbee
The Aqara Smart Door Lock A100 Zigbee is the enhanced version of Aqara’s first smart door lock. It’s compatible with Zigbee and Bluetooth to ensure you have easy control of the lock at all times. The batteries should last for around 18 months before you need to replace them. Even if these batteries run out, the A100 model includes a USB-C port and mechanical key to make sure you always have access to your home.
You’ll notice that the lock’s keypad is invisible until you touch it. This pad comes with an Away Mode button that ensures the device remains locked until you arrive back home. The button can also trigger other mode functions like turning off appliances and lights, turning on the vacuum robot, etc., when you leave your home.
Along with the nine unlock methods at your disposal, you also have three types of alerts that can be sent to your Alexa-compatible device, which include a long-time opening alert, a tamper alert, and an abnormal attempts alert.
Aqara Smart Door Lock N100 Zigbee
The Aqara Smart Door Lock N100 Zigbee supports Zigbee 3.0 and is the international version of Aqara’s most popular lock. It comes with 18 months of battery life and seven unlock methods that you can take advantage of.
The handle and frame are made from a high-quality anodized aluminum material that provides you with superior durability. This lock is capable of recording who opens it and what method they use to do so.
You can then configure different types of automation depending on who arrives at your home. When someone rings the doorbell, you’ll receive an alert on your smartphone or tablet immediately.
What To Look For In A Smart Lock To Use With Alexa
Not every smart door lock is compatible with Alexa, which is why it’s important to look for features that indicate compatibility.
Smart locks that accommodate Alexa will be outfitted with voice control functionality, which makes it possible for you to open or lock your door using simple voice commands. Door locks that don’t advertise this feature likely aren’t compatible with Alexa.
How Much Do Alexa-compatible Smart Locks Cost?
Alexa-compatible smart locks usually cost anywhere from $200-$800 depending on the model you choose. Higher-priced models typically come with better features and more extensive functionality.
Where To Buy A Smart Lock For Your Alexa-powered Smart Home
While Alexa-compatible smart locks are available from many different suppliers, your best option is to buy with Aqara—your reliable smart lock provider that knows what it takes to keep any home or office secure. When you shop for Aqara smart locks you’ll find them online and instore from retailers like Amazon, Home Automation Shop, Newegg, and The Home Depot.
