Smart Hubs
Browse the Aqara range of smart hubs. These are the heart of your smart space, through which you can connect to all your smart devices.
Hub M100 product picture
NEW
Hub M100
Mighty Hub, Minimal Size
Hub M3
Continuous Connectivity for Your Smart Devices
Camera Hub G2H Pro
Camera G2H Pro
camera hub g2h
Camera Hub G2H
aqara hub 1
Hub M1S
Hub M1S
aqara hub 1
Aqara Hub
Aqara Hub
The Hub of Your Smart Home
A smart hub is essentially a control center for the smart devices in your home. The hub lets you connect, communicate, and manage different devices from one interface. You can control your thermostat, security cameras, smart lights, your door locks, and more. Thanks to combining Wi-Fi, Zigbee, and Bluetooth, you can receive notifications, access your smart features with your smartphone, or even use voice commands via your virtual assistants, like Amazon Alexa or Google Assistant.
Here are some reasons you’ll want to consider getting an Aqara smart home hub.
  1. Compatibility – Aqara smart home hubs provide seamless connectivity for Aqara Zigbee devices, with some models also supporting Aqara and third-party Matter devices. Once connected to an Aqara hub, these devices can be controlled via the Aqara Home App, as well as through third-party ecosystems like Apple Home, Google Home, Amazon Alexa, and SmartThings.
  2. Versatility – The Aqara smart home hubs stand out because of how versatile they are. You can integrate and control sensors, switches, smart lights, and more. In fact, you can fully customize and interconnect your smart home ecosystem with one of these nifty smart home hubs.
  3. Ease of Use – With everything the Aqara smart home hub can do, it’s surprisingly user-friendly and straightforward. Users will get an intuitive mobile app that makes the setup process easy. They can then create automation routines and set the app up to receive notifications.
  4. Security – Because everything connects to the Aqara, the company has made security and privacy fundamental features. These smart home hubs use advanced encryption techniques to protect your data and ensure your smart home environment is safe.
  5. Integration with Voice Assistants – Aqara smart home hubs let you take control to the next level with its use of Amazon Alexa and Google Assistant. Don’t feel like walking over to the smart hub? With a seamlessly integrated voice assistant, you won’t have to. You can control your Aqara smart home hub through voice commands.
Smart Hub FAQs
A smart hub is designed to connect and control your smart devices, acting as a central control center. A voice assistant (Amazon Alexa, Google Assistant) is an AI system that responds to voice commands, performs various tasks, and provides information. You can sync your voice assistant to your smart hub, but the two serve different functions.
A bridge acts as a translator between devices, so they can communicate with each other. It allows devices on one protocol to communicate with devices on another protocol. A smart hub, on the other hand, connects the devices so that they can be controlled and managed from one device.
Your smart hub may need Wi-Fi to communicate with your smartphone or receive updates. However, the Aqara hubs use Zigbee to communicate locally with the smart devices in your home, and this network doesn't need a Wi-Fi connection.
Smart home hubs use protocols such as Zigbee and Wi-Fi to connect with smart devices.
No, not all smart devices require a smart home hub. You can control some smart devices directly through their mobile apps. However, if you want to create one centralized control system, an Aqara smart home hub lets you do that.
As long as you have an internet connection, controlling your Aqara smart home hub remotely shouldn't be a problem.
Yes. In fact, you can use Amazon Alexa, Google, Assistant, and Apple Siri to give voice commands to your Aqara smart home hub.
Absolutely. Aqara smart home hubs let you automate tasks, such as setting schedules, turning off lights, locking doors, and changing your thermostat settings. You can also get the IFTTT automation platform with some Aqara hubs.
