Global Security & Compliance Statements​
We do our best to provide continuous security updates for our IoT products. The security updates generally include the latest security patches, security vulnerability fixes, and other security improvements. We will maintain the security updates for at least 2 years from the launch day of certain device models.
  • Australia
  • United Kingdom
  • EU_Data_Act
SOC Documents
Our smart home devices sold in Australia comply with the Cyber Security (Security Standards for Smart Devices) Rules 2025, which came into effect on 4 March 2025.
The Statement of Compliance is prepared in accordance with Australian legislation and applies to products sold within Australia. We will review and update these documents as regulations evolve.
Product Name Model Status Date Issued Document
Camera E1 CH-C01E Active 2025-08-20 View PDF
Camera G100 CH-C08D, CH-C08E Active 2025-08-20 View PDF
Camera Hub G3 CH-H03 Active 2025-08-20 View PDF
Camera Hub G5 Pro (POE) CH-C03E, CH-C03D Active 2025-08-20 View PDF
Camera Hub G5 Pro (Wi-Fi) CH-C07E, CH-C07D Active 2025-08-20 View PDF
Camera Hub G2H Pro CH-C01 Active 2025-08-20 View PDF
Ceiling Light T1M CL-L02D Active 2025-08-20 View PDF
Climate Sensor W100 TH-S04D Active 2025-08-20 View PDF
Cube T1 Pro CTP-R01 Active 2025-08-20 View PDF
Curtain Driver E1 CM-M01 Active 2025-08-20 View PDF
Doorbell Camera Hub G410 CH-C09E, CH-C09D Active 2025-08-20 View PDF
Doorbell Camera G400 (Wired) DB-C03E, DB-C03D Active 2026-02-03 View PDF
Door and Window Sensor P2 DW-S02D Active 2025-08-20 View PDF
Door and Window Sensor T1 DW-S03D Active 2025-08-20 View PDF
Dual Relay Module T2 DCM-K01 Active 2025-08-20 View PDF
Hub E1 HE1-G01 Active 2025-08-20 View PDF
Hub M1S Gen2 HM1S-G02 Active 2025-08-20 View PDF
Hub M2 HM2-G01 Active 2025-08-20 View PDF
Hub M3 HM-G01D Active 2025-08-20 View PDF
Hub M100 HM-G02D Active 2025-08-20 View PDF
Hub M200 HM-G03D, HM-G03E Active 2025-08-20 View PDF
LED Bulb T1 LEDLBT1-L01 Active 2025-08-20 View PDF
LED Bulb T2 LB-L02E, LB-L02D,LB-L03E, LB-L03D Active 2025-08-20 View PDF
LED Strip T1 LEDS-K01, LEDS-K02, RLS-K01D, RLS-K02D Active 2025-08-20 View PDF
Light Switch H2 Vertical WS-K04E, WS-K03E, WS-K02E Active 2025-08-20 View PDF
Light Switch H2 Horizontal WS-K14D, WS-K13D, WS-K12D Active 2025-08-20 View PDF
Motion and Light Sensor P2 ML-S03D Active 2025-08-20 View PDF
Motion Sensor P1 MS-S02 Active 2025-08-20 View PDF
Multi-State Sensor P100 VB-S03E,VB-S03D Active 2026-01-30 View PDF
Presence Sensor FP1E PETC1-M01 Active 2025-08-20 View PDF
Presence Sensor FP2 PS-S02E, PS-S02D Active 2025-08-20 View PDF
Presence Multi-Sensor FP300 PS-S04E, PS-S04D Active 2025-08-20 View PDF
Pet feeder C1 PETC1-M01 Active 2025-08-20 View PDF
Roller Shade Controller T1S CD-M03D Active 2025-08-20 View PDF
Roller Shade Driver E1 RSD-M01 Active 2025-08-20 View PDF
Single Switch Module T1 (No Neutral) SSM-U02 Active 2025-08-20 View PDF
Single Switch Module T1 (With Neutral) SSM-U01 Active 2025-08-20 View PDF
Smart Door Lock A100 ZNMS02ES Active 2025-08-20 View PDF
Smart Door Lock D100 ZNMS20LM Active 2025-08-20 View PDF
Smart Lock D200i (SEA) ML-D01D Active 2025-08-20 View PDF
Smart Lock U50 DL-D05D Active 2025-08-20 View PDF
Smart Lock U100 DL-D01D, SDL-D01 Active 2025-08-20 View PDF
Smart Lock U200 EL-D02D, EL-D02E Active 2025-08-20 View PDF
Temperature and Humidity Sensor T1 TH-S02D Active 2025-08-20 View PDF
U200 Adjustable Cylinder AL-D01D Active 2025-08-20 View PDF
Smart Video Doorbell G4 SVD-C01, SVD-C03 Active 2025-08-20 View PDF
Smart Lock U300 (& Matte) DL-D02D, DL-D02E Active 2025-08-20 View PDF
Smart Lock B50 DL-D12E Active 2025-08-20 View PDF
Valve Controller T1 VC-X01E,VC-X01D Active 2025-08-20 View PDF
Vibration Sensor T1 VB-S01D Active 2025-08-20 View PDF
Water Leak Sensor T1 WL-S02D Active 2025-08-20 View PDF
Wireless Mini Switch T1 WB-R02D Active 2025-08-20 View PDF
Wireless Remote Switch H1 (Double Rocker) WRS-R02 Active 2025-08-20 View PDF
