Aqara Debuts its First Smart Lighting Device for Global Markets
(New York) August 15, 2023 – Aqara, a leading provider of smart home products, introduced a multipurpose, RGBCCT lightstrip, the LED Strip T1, to the global markets. As the Company’s first smart lighting device that is widely sold across multiple continents, the LED Strip T1 not only displays up to 16 million vibrant colors but also provides tunable white accent lighting. Moreover, it supports a wide range of third-party smart home platforms and can be seamlessly integrated into various smart home setups. The new light strip is now available on the Company’s Amazon brand stores in North America (US, Canada) and Europe (France, Italy, Spain, UK) as well as via selected Aqara retailers worldwide1.
Built upon the Zigbee protocol, the LED Strip T1 has a lower idle power consumption than the Wi-Fi based lightstrips, making it eco-friendly and cost-efficient. It also serves as a repeater of the Zigbee network, which further strengthens network reliability and responsiveness. With a compatible Aqara hub such as the Hub M2, the LED Strip T1 supports the new IoT standard Matter as well as popular systems like Apple Home, Amazon Alexa, Google Home and IFTTT, and can be controlled by major voice assistants2.
The LED Strip T1 is 2 meters (ca. 6.6 ft) in length, and can be extended using the Company’s 1-meter Extension Kit3. It supports a maximum length of 10 meters (ca. 33 ft). The lightstrip can be cut at 20 centimeter (ca. 7.9 in) intervals4, making it highly customizable. The cut or unused part of the lightstrip can also be reattached to a separate Aqara LED lightstrip using extra standard 5-core ribbon cables and 5-pin connectors5
More importantly, the RGB effects of the LED Strip T1 are independently addressable with a 20-centimeter interval, which means that it can display up to 10 different colors with dimming and other effects6. The Aqara Home app provides various built-in effects for the LED strip – both static and dynamic- and allows users to customize the lighting effects as they prefer. All these built-in and customized effects can be used for home automations and scenes so that users can integrate smart lighting into the holistic smart home experience.
For example, users can amplify the home alert system with the LED strip, using different colors or effects to indicate whether the security system is armed or not and if there is a potential threat. It’s also possible to create customized home scenes, such as an evening scene with warm lighting or an entertainment scene that dims the lighting for a better movie watching experience. The Aqara Home app recently introduced a new feature allowing users to sync the scenes to HomeKit7. This means that users can set up specific scenes that were previously only available via Aqara app and be able to control these scenes with third-party apps such as Apple Home, Alexa, and Google Home.
Other features of the LED Strip T1 include:
  • Manual controller for easy access: a physical controller allows users to turn on/off, switch lighting modes and activate the music sync mode without using any mobile apps.
  • Local music sync mode: the LED Strip T1 can sync to the music locally without relying on the mobile device.
  • Circadian lighting: the LED Strip T1 supports Adaptive Lighting in Apple Home and allows user to customize the circadian lighting schemes in Aqara Home with automations.
  • Outdoor friendly: the LED Strip has an IP44 rating and can withstand dust and moisture, making it suitable for some outdoor user cases8.
For more details on the LED Strip T1, please visit our website.
1. Product availability may vary among different retail channels and could be updated on an ongoing basis. It’s recommended to check with the regional retailer(s) for real-time availability.
2. The Matter compatibility of the LED Strip T1 requires a Matter-compatible Aqara hub (such as Aqara Hub M2, Hub M1S/M1S Gen 2 or Hub E1) and may be in Beta by the time of its launch. The Matter compatibility of the G3 Camera Hub is being rolled out, and is expected to reach all users by the end of August.
3. The LED Strip T1 Extension Kit is sold separately.
4. The cut lines are marked on the Lightstrip.
5. The 5-core ribbon cables and 5-pin connectors necessary for any reattachment are not included, and the reattachment deactivates the IP rating of the Lightstrip.
6. Only the RCB colors and lighting effects are individually addressable. The tunable white effects apply to the entire length of the strip.
7. The Aqara Home app version of V4.0.2 or newer and the Aqara hub firmware version of V4.0.4 or newer are required for this feature.
8. The IP rating is only applicable to the LED lightstrip, but the Manual Controller and the Power Supply are not weatherproof and should be used indoors.
The Dual Relay Module T2 is now available! Learn More
